TheVicster
- Nov 14, 2010
- 67
- 3
who is using what media player? I've tried a couple of different ones, but can't find one that recognizes the external sd card. The stock player does, but none of the media player apps "sees" the card.
I'm not even showing bars. I see AT&T but no bars. I'm not having a whole lot of luck with my S7 so far, although I still like it.
i see bars on my phone..., but cannot connect...![]()
Can you make voice calls? After you made the APN changes did you reboot? Also check this link out, this person claims it works on his HTC Dream/Magic Android - HTC Dream/Magic - Fido APN/MMS Settings - xda-developers I would think the settings would be the same.
I use Rockplayer - the Rockplayer Universal which is available from Market lets you set default root directory, I use "/sdcard2". I am then able to browse my external sd card and play videos, even .avi (remember to select "software acceleration" or whatever it says (I don't have the S7 in front of me at the moment).who is using what media player? I've tried a couple of different ones, but can't find one that recognizes the external sd card. The stock player does, but none of the media player apps "sees" the card.
Just tried this. Can't get the setting to stick when I change the default directory to sdcard2. In additoin, it just keeps crashing on me, and going back to the screen where it wants you to buy it. Don't know if this is some kind of glitch, or the programmer has done this on purpose to force you to buy.I use Rockplayer - the Rockplayer Universal which is available from Market lets you set default root directory, I use "/sdcard2". I am then able to browse my external sd card and play videos, even .avi (remember to select "software acceleration" or whatever it says (I don't have the S7 in front of me at the moment).
~Christopher
thanks this worked for me!Vicster,
I just cleared that whole space and can use the back button to navigate to either card. Should work the same for you.
I have a logitech media board at work and that bluetooth mouse. I will try them in the morning. The logitech keyboard has a track pad on it.was anybody able rto connect a bluetooth mouse. i have the microsoft bluetooth mouse 5000 and althought i can pair it, i do not know how to connect it to work with mini opera which does have a cursor?
They are both bluetooth. I tried both aswell and they say paired but not connected. So niether one is working as yet. Do not know about the the USB host/slave.thanks and also i was under the impression that the micro-usb was both a host/slave? is that correct?
