- Sep 24, 2010
- 3,649
- 561
Jason -
did you review the following link? Android Ad-hoc support hack/wpa_supplicant - xda-developers
Peter
Peter
Jason -
Peter
Attention:
- It _seems_ like some rom using wpa_supplicant v0.6.x do not work!
adb shell wpa_supplicant -v should tell you
do you have terminal emulator installed? If not, get one from the market. Then it is just wpa_supplicant -v
hmm....then odds are you are not actually rooted properly. I have found that UniversalAndroot can sometimes give a "false positive" in what it does and what rights it has actually granted. Try re-rooting your device using z4root, also available from the Market.
A wild shot here, it is possible that the new wpa_supplicant was actually working, but you need to disconnect wifi and reconnect or something? Turn it off and back on. The message you saw might just have been it failing to reconnect after the boot. Give us more info, when it didn't work, could you still see networks in the WiFi setup? Be sure to pick a different channel for your phone than your home router. Otherwise I guess I don't know.
Well, I don't know, unless you have a corrupt file or something. Why would it give you a not enough space error? It should be 312,440 bytes long.
