I need help
Dec 28, 2010
My little brother has put one of those pattern codes on his Android DreamBook and he says he puts it in correctly, but its not working so.... i need a way to unlock it? or just reset it or something... Help would be handy.
Search is your friend. We have threads on this topic already. You can try doing a factory reset, which wipes everything.
Are you sure you don't wanna give me an opinion. Because i tried all the stuff on this one thread... and the java just died and didn't install for no reason. It'd be alot easier if you could give me a proper answer as **** likes to just..... not work for me.
I can feel the frustration waves coming off you....we have all been there.
Depending on your device there should be a key combination that you can use to power on the device and perform a factory reset. It will just be a trial and error thing, as I do not know the combo for the Dreambook, but try these from a power off state:
Try holding down your volume keys and then power key
or
Back button and power key
or
Volume Down and power key
Keep in mind, this will reset your device to factory defaults and will likely erase any apps you have installed.
