"Internal nand storage" problem with C71
amincom
I have ZTPAD tablet version C71- 1G
My tablet problem is it can't recognize "Internal nand storage" so all application can't store data on it although i can see "Internal nand storage" drive by tablet & PC file explorer and also can store files on it.
And if "SDcard" inserted,tablet use it as the normal "Internal nand storage" and put "Android" folder & applications data on it
Could you please help me to fix this problem.
Go to storage in settings and make sure it's mounted
Sent from my LT26i using Tapatalk 2
Also try flashing new firmware with a complete wipe
It's mounted but as external sd card not nand stortage,so applications can't save data on it
Sent from my GT-N7000
Oh! That is strange! So you don't have an external sd in too?
Assuming not, if you put one in where does it show as mounted? (in settings - storage)
I had to use esternal sd and the strange thing the device & applications use it as nand storage to put thier data on it.
