mookzilla101
- Jan 5, 2011
- 8
- 0
figured it out. it was because i didnt have enough room on my sd card.
For those that installed the SDK Manager under Windows 7 64 bit, I need some help.
When I launch SDK Manager, I get a dialog box about the path being wrong to Java.exe
Java is definitely installed and I follow the instructions to force the path but this does not work. There are a few topics on this on the WEB about SDK and win 64 but so far no luck.
Anyone have some Ideas? This is not about the USB drivers as I haven't even got that far. (tablet rooted though using the simpler approach elsewhere)
I had the same issue on Win7-32bit. First, I removed the SDK and then when I installed it, I did an "Accept All" and installed everything. Next, I pasted in the two parts of the inf file as instructed. The key was when I plugged in the unit and went into Device Manager, I right-clicked, update driver. HERE IS THE KEY -- I selected Browse for Drivers, then I chose "Let me pick..." and on the next screen I had to uncheck the box that says "Show compatible hardware" which shows more devices. Then I chose "Android ADB Interface" NOT "Android Composite ADB Interface".
Everything worked great after that. I tried the same thing before I uninstalled and reinstalled everything, so make sure you re-do the whole SDK part as I instructed.
I used this forum and downloaded the tool on windows 7 after which my android is recognized by windows 7. Hope this will be help you as well. Best of luch
I know this is not a reply, but a call for help. My Kryos 7005 stopped showing video in youtube. Says loading video, then get sound but no video of the youtube program that is running. What happened? It will play the video on the tv through the hdmi but will not show video on the tablet? I could sure use some help
