When I am in command prompt and I go to cd/android-sdk-windows/tools "Enter". When I type adb shell it tells me that its not a recognizable internal or external command.
Please help
i was using the same command :
cd/android-sdk-windows/tools and the same thing :
its not recognizable internal or external command
so i google and found this:
cd C:\
cd android-sdk-windows
cd platform-tools
Type: adb shell and press enter.
Type: su and press enter.
Type: flash_image recovery /sdcard/recovery.img and press enter.
Press and hold the CTRL button, then press C.
Type: adb reboot recovery and press enter.
for me this worked
i did, but i got the prompt message after i type: mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
it shown mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak file not found
do i missing something?
It took me a week but I finally got it to work after re-rooting with z4root v. 1.3.0. Then put recovery.img & the market zip file on the root level of the sd card, meaning not in any folders. Start the virtual terminal app & typed su, superuser then asks to allow, now this is very important, you have to clear the keyboard so you can push the allow button that the keyboard covers. once you push allow the # appears and you can continue.
Someone please answer this, I also have the 7005 and want to root it. I just dont want to follow these instructions and brick my tablet.
