So, if you have the high pitch (or whatever term you use to describe the weird sound? ) problem with music or video while you are using superhansi's CM10 build, please just reply "yes". Otherwise reply "No".
Again, only reply this if you are using CM10, once again CM10!!
Sorry i don't know how to make the thread becomes vote section, so yeah I just want to narrow down the problem
Alright the way to solve sound problem, copy and paste directly from flash's comment: Here's the media codec file , just place in the etc folder and change permissions , rebootDev-Host - media_codecs.xml - The Ultimate Free File Hosting / File Sharing Service
All credit goes to flashallthetime
Update: Problem solved!!!!! Either use the way flashallthetime mentioned, or download the ROM and do a clean install: Development: Cyanogenmod 10 for the A2109 - Page 20 - Lenovo Community
