OXOR
- Aug 23, 2012
- 8
- 0
Hi...
I'm a rookie on android and tablets... and i've a problem with my new N90 II:
-when i just click on the cam software give that error “Unfortunately, Camera has stopped” with the button “ok”, i reseted to factoty defaults and the cam's worked for a while, then the same problem... i fill that is a software problem, how can i solve it? i'm very new in android and i dont know if needs drivers info , or how can i reinstall the cam software, because i dont find the installer...
can some please help me???
tnks
note 1: already install other software's and gives the same error...
Note 2: i've a N90 II with that info:
Model: rk30sdk
Firmware ver.(tr976_rk610_rk903_ov2659_ov2659_rk30hdmi_otg@12070 9)_mc_cn@120709)_v404.11_tl12
need the kerner ver. and the compilation number?
tnks
Model: rk30sdk
