My rooted NC 1.1 has stopped reconnecting automatically to my wifi network after sleep. It had been working fine for a while so I am not sure what changed. To get it to reconnect I either need to toggle the wifi on/off or select the network using wifi settings. After that it is fine. If I just put it to sleep and turn it back on after a minute or so it connects fine. The problem occurs after several minutes (say 10) of sleep.
I have deleted all my network connections, rebooted and then connected to my network with no change. Again this had been working fine in its current state.
I then reimaged it to a known working image using CWR but the wifi issue remains.
This is more nuisance then anything else but it sure is annoying.
Look forward to any suggestions since I dont know what else to try.
Bob Silver
NC 1.1 rooted 1.1ghz
Ipad 3g 4.2.1
Iphone 4 IOS 4.1 jailbroken
Bob Silver
Ipad 3g 4.2.1
