I had the 1.1 firmware installed on my stock NC but I ran into issues getting the Nooter3 to install correctly. So I rolled the NC back to 1.0.1 using CWR. I tried several times to re-install the 1.1 update on my NC, but it wouldn't work after the first time.
I downloaded the update, copied the file to the root of my NC, and every single time, the zip file just disappears from the drive.
Any thoughts on why the file disappears, and why it doesn't install?
I might try one more time by using CWR to roll it back, and then use CWR to install the 1.1 zip file. I'm just confused by the behavior of the software with this update.
