Need a root solution for Mid7022
Yes, i need to learn more, i will
Let me know if you want me to test something for you
Thanks for your time, i will report back in case i get a original LK into my hands, debating right now with level 2 support of coby
They tell me to send it back and they will send me another one but i want to keep this one, has a very good screen, no bleeding, no dead pixels, no HW problems whatswhoever
Tell them to release source rom :)
yup if you can get original lk.rom for 7022, it will help this and future accident :)
coby's support stuff may not know technical thing about lk.rom, but they should be able to ask their factory about it.
good luck!
i can try, i found a guy from LVL2 support who talks to me
Tommorow i will linger to Toys R US and get another one, u guys know, is there a way to extract the rom ?
I found this resource Index of /romdump , i tested it, does not work , looks its a older version, i wonder if they work on a update, i cant find the email address from the developer, i would contact him
I just noticed, romdumo would only have dumped BOOT, RECOVERY and SYSTEM , that does include MD0 Layer... there must be a way to extract the data from MD0
I am sorry if sometimes it does not make sense what i am saying, i am a tech and i did that stuff 15 years ago , with Amiga's and blueboxing and other mod's, i learn on my way, i try to put everything together but there is so much "wrong" info out there, getting confused sometimes
any idea how extraction can be done otherwise ?
The below instructions worked beautifully for me. Thanks a lot!
* How to install/use ClockworkMod Recovery 4
1.Download this file http://api.viglink.com/api/click?for...ery-signed.zip
2.In windows format your SD card as FAT32 (not quick format)
3.create a folder by name sdcard in your SD CARD
4.Copy the above downloaded file to sdcard folder
5.rename the file as update.zip
6.Insert the sd card to MID7022
7.Go to Settings --> About Device -->System Updates --> Install System Updates --> FromSD card
clockworkmod will be booted on next reboot recovery.
Credit goes to fun_@http://forum.xda-developers.com
Now you should be in recovery console.
FIRST thing to do is backup your STOCK ROM
Navigation keys on clockworkmod, MENU = next item, HOME or POWER = select, BACK = back.
Once backup is completed. Please save the backup to secure location other than SD card
Now reboot the tablet.
Rooting
1.Insert the same SD card to your PC
2.Goto Superuser 2.3.6.3 [17 June 2011]
3.Download Eclair/Froyo/Gingerbread/Honeycomb
<http://downloads.androidsu.com/super...fgh-signed.zip>
4.Copy the file to /sdcard folder in your SD Card
5.reboot your MID7022 into recovery mode.
to reboot recovery
1.power down the tablet
2.hold power and back button( round silver button)
this should bring up clockworkmod recovery console
6.select install zip from sdcard
7.browse and select su-2.3.6.3-efgh-signed.zip
it should install and root your device
8. enjoy your new rooted MID7022
Bala
Rooting
to reboot recovery
Bala
Just to be absolutely clear, does this mean that it is not necessary to install CyanogenMod in order to root the Kyros 7022?
No do not install cm7!!! You just need clockword mod recovery
Got my MID7022 rooted and ClockWorkMod installed. Works great. Just follow Fun's direction to the letter. I can't thank you enough, Fun. I bricked my 7024 by following bad advice. I was a little more particular with the 7022. I am a happy user, now.
Im new to this. Does clockworkmod=honeycomb? Can we get honeycomb on the 7022?
Clockworkmod is a replacement for the stock recovery. In there you can backup your current rom (stock 2.3.3) and also flash custom released roms such as honeycomb as well as obtain root access. However at this time no custom rom exists that works correctly. If coby or telechips would release a kernel source then someone would probably develop honeycomb
The tablet is still pretty new so hopefully we can expect custom roms in the future. Even the mid7015 has a honeycomb rom out.
This method is temporary root, is there a way to get perm root done ? any ideas ?
/system is R/O and needs to be R/W manually
not complaining, just want to know if anyone got perm root done yet
Not sure what is permanent root and temporary root. Rootcheck says I have root. SU works. I have full access to all files and folders, I kind of like having to manually mount as r/w.
