Newbie with superpadVII firmwware problem
arrowheaduk
HI
Im a newbie to this so please bear with me.:p:p
I currently have a superpad VII which is stuck on the android screen.I have searched the web for solutions, and have found out that I will need to upgrade firmware as the currently version is the firmware shipped by manufactor and I need to upgrade (via SD card) to 1480.
This is all good except one Ive never done this before and 2 I cant find a copy of the firmware I require.
I may be barking up the wrong tree here but this is the solution I seem to have found trawling the web.
Could anyone help me get this pad back in working order by pointing me to a site to download this firmware so I can attempt to boot from sd to upgrade the firmware ;)or suggest some other solution.
model bt1003
I cant give much more specs as I cant get into it.
I have tried all the button combinations with no result say to see the android robot lying on his side with a exclamantion mark sticking out of him.
Any help is gratefully ;)
Thanks again for the input , have done as suggested without luck , in truth I had already attempt to find suppliers site and again sadly no luck.I have read thru this forum and found this page
http://www.androidtablets.net/forum...ow-restore-your-flytouch-2-1170-burntool.html great info and suggestions with the exception of the download site for the is not operating.
So again a blank.
Maybe I should use pad as paperweight
But if you have any further ideas please let me know.....
Thanks again
