- Jan 6, 2011
- 5,172
- 899
1. Use the browser to go to m.youtube.com, select a video and then try to play the video. All you will get is black where the video should be.
2. Start where you left off above and scroll down to the very bottom of the page and tap on the word "Desktop" then select browser. Now you will be able to see the video you could not see before and you will even be able to pause the video by tapping on it but that is all you can do until you tap on the words "show more" below the video. After you tap on the words "show more" then you can tap on the video to restart it.
3. There are other problems that can be tracked down to the Adobe Flashplayer but all I really want Vizio to do is let me put my VTAB1008 back the way it was before their unnecessary Honeycomb update that has been a lot more trouble than it is worth.
1. Why are you trying to use mobile youtube instead of just using the app? There is an app for a reason and it should provide a better experience than trying to go through the browser anyway.
2. Again, why don't you use the youtube app instead of the desktop browser mode?
3. If what you are really saying is that you are having problems with Flash then that is your problem, not the Honeycomb update itself. Why don't you follow the advice in several threads and side load the newest Flash version which should solve your particular issues?
Given sometime Adobe/Vizio may address the Flash issue. If this is a Flash issue then you just need to wait for that to be corrected, it doesn't make Vizio or Honeycomb bad in itself. App compatibility issues are the responsibility of the app developers not Google or Vizio.
