Cant wait for a better BT fix that can hold the connection in much bigger distance.Right now having NC next to receiver to hold the gps signal is a big problem.
I dont have an Android phone.You might want to try TetherGPS. Here's my hands-on video:
]Installation is easy, you just need to install TetherGPS on both your phone and your Nook Color.
I was with PD 6.1 I think when I used it and before this version of Sygic, I had same errors this U.How you do it?
What Version of android (CM 7 stable or a nightly)?
How you install sygic?
I install sygic (SygicNavigator_11.0.1_CNSTeam), download maps, start sygic and "The application Sygic (process com.sygic.aura) has stopped unexpectedly. Please try again." message pop up.
What I do wrong?
I try with CM7.0.3, CM 7.0.2, CM nightly and phiremod latest.
Can you help me figuring out what I do wrong?
With this version of Sygic, I just have to get GPS signal first (with true or fake gps receiver) and then Sygic starts just fine.
Now with PD 6.3 everything still works great.Also with other Igo app.
