HOW TO UN-BRICK A "HARD"-BRICKED Coby MID8024.
Yes, I did it. I un-bricked my Coby 8024. While installing the gingerbread ROM "C8lean 1.1 meshed.rar" by "elemist2" I "hard" bricked my Coby. A "hard" brick is not the regular recovery mode(pressing power button and HOME/SILVER button at the same time) that the Coby uses to install new roms. It is a state that the Coby goes into when the NAND becomes corrupted for some reason. When this happens the Coby appears dead to the outside world, even to the USB and HDMI ports. The NAND appears to have only one purpose and that is to hold the bootloader, see the thread "Creating a proper system layout" by "fonix232" at SlateDroid for more information. BORING!!!! Ok, onward.
Anyway, you can unbrick a mid8024(maybe 7024) with very little work, but you have to open your Coby for this to work. This method is only for a "Hard" bricked Coby8024(7024). If, you have a regular "soft" bricked Coby first try the regular method before attempting this one.
Also, I didn't do this first, "vinylb" at SlateDroid did it back in February. Look for the thread "How to unbrick your Coby MID7015". I used a slightly different approach.
You will need the following:
1)VERY----VERY small screwdriver or metal probe.
2)The original Coby ROM. Once you get the thing working you can always throw another ROM on it.
3)MicroSD card, just big enough to dump the ROM.
4)A opened Coby .
The Fun Part.
1)I used a 8G microSD card that was partitioned with the file "u-boot-SD.bin.mid703v3.mm". I won't bore you with the details because if you are reading this article you have exhausted all other options.
Just put the original Coby ROM into the FAT32 partition. Put the microSD card into the Coby external slot. SIMPLE!! HARD PART COMING UP!!
2)Ok, if you don't know where your NAND is stop reading now and go find out. With the Coby open and the microSD card in the regular external slot you have to take that VERY small screwdriver and stick it between pins 7 & 8 of the NAND chip. You just have to short pins 7 & 8,how you do it is up to you. Simple.
3)With pins 7 & 8 shorted you now just do a regular plain-Jane recovery mode procedure. Simple.
I just shorted pins 7 & 8 on the NAND chip and did power button and home button at the same time.
The Coby screen turned bright white(all white) and I just let go of the power button and something "wonderful" happened. The Coby stayed on!! Yes, after 3 weeks of turning off whenever the power button was released it "stayed on". Yes, "something wonderful" happened.
I held the screwdriver against pins 7 & 8 until the Coby turned off by it self, which was about 4 minutes....give or take.
I flipped over the Coby, remember its still in 2 pieces, and pressed the power button, and .....and....
Saw "COBY". YEPPIE!
WARNING!!! I tried over 20 different recovery methods from over 4 different forums before I tried this. The Coby never gave me any sign through screen, USB, or HDMI. Just soft menu buttons lighting up with the power button press. It was DEAD! I didn't have any other options. Nothing else worked. I had nothing to lose. If, you have any questions just ask before attempting this method.
Any comments, suggestions, money, gifts, or whatever can be just posted to this thread.
Thank you for taking the time to read this article.
Bye...
Arlic
OK, bricked again, trying Arlic's method but it's stuck on "updating bootloader"
MID 7024 using CFW-7024-v2
What am I missing?
Edit - Used the 2G InternalMemory off the CFW-7024-V2. Went back to the original and seems to be working...
Worked like a charm! I shorted the 7 & 8 pins once I had the card set up and it found the sd card and booted and installed the firmware. from there I was able to flash the official firmware and everything works like normal. Arlic, you are awesome for discovering that! now hopefully this means the tablet is pretty much unbrickable with this little work around
i think my kyros had a 1025 board, anyone knows how can i revive it?
Hello... I have a stock, non rooted, 1024 with a 1025_v4 board (I´ve opened it yesterday to confirm). Its dual touch and is working fine.
If there is something I can do to help in your project please tell me.
adb shell dmesg > dmesg.txt
dmesg > /sdcard/dmesg.txt
Hi.. here is it... dmesg.txt - 4shared.com - document sharing - download
[ 6.641677] Goodix-TS 1-0055: Guitar Version: GT801NI_0R01_211
