- Thread starter
- #61
Awsome job steev. would this be the same for the 7042?
Yes, the 7042 firmware I posted is rooted also.
Also...just wanted to take this opportunity to publicly say thanks! You're whillingness to crack away at a machine you don't even own is absolutly awesome! If the world were filled with more people like you (that not only have the knowledge to do this kinda work, but the drive to do it just because it should be done), it would be a far happier place! So really, thank you!
@steev - Thank you very much.
Can you recommend a good Gogle Play Store, Gapps package installer?
when I flash the new image I know I will probably lose all firmware settings but will I lose installed programs?
7042, Application came back with "Update successful". But touch screen is unresponsive. The upgrade looks god but the touch screen does not work on the demo. Pressing the power button will put the device to sleep bu then you cannot unlock.
Actually I tried both. I am running again..
No luck with the reload..
