[ROM] Akop Slimrom Port Nexus 7 JB 4.1.2
I got my help from a developer on xda that I helped,
Sent from my Evo 3D GSM using Tapatalk 2
OK slimrom is ready for me to upload, camera is not fixed, sound is perfect now. Paranoid ROM is being worked on now
Why does 4.2.2 roms partition the internal with o and legacy partitions? Just ported a 4.2.2 rom and it's not ready for primetime
They separate them for supporting multiple users (each user will get their own data partition).
Thanks, I am running a 4.2.2 ROM on my phone and no seperate partition , the navigation bar is messed up on the 4.2.2 ROM , could be DPI has to be set to 213 same as nexus 7 or again I have to pull apart the framework.res and alter it.. can some else start developing or if someone would help, it would be much appreciated. I am finished with the paranoid ROM. I think I have a better chance of improving one ROM at a time
Sent from my a2109a using Tapatalk HD
Well sorry folks , as superhansi has a working unofficial slimrom 4.2, development has stopped on this
Sent from my A2109A using Tapatalk HD
Exactly the same issue with superhansi slimrom has, solve it and my ports will be fully functional
Let me try to use the camera file from TF300's CM10 ROM. :)
Any possible file suggestion for me to mess around? :p :p
Seems like you're bored mate lol:D
Ahahaha you know it:p
Hmm so even the 4.1.1 camera gets the same error, then its possibly something wrong with the jpeg generation (I think flash mentioned it before somewhere?)
I think camera works on cm10 4.1.2..if somebody is not lazy to install and get info on logcat
Sent from my SGH-T999 using Tapatalk 2
Unfortunately libs are probably the issue, now for the really bad news. If it is the libs this ROM probably won't boot or more issue and problems will happen, so saying that. I will put out my latest update with working storage settings and sound fix. Same with my paranoid rom
Doomboss , I tried everything, switched camera with the nexus, media profiles XML switch
