powerpoint45
- Sep 9, 2012
- 78
- 19
- Thread starter
- #31
bmcl1993 said:Hell, if I use Virtual Box will work??? any linux??? ubuntu works???
I think virtual box would work. An yes Ubuntu works.
dbeauch said:Ohhhhh you scroll down! hahaha, lol, sorry!
You mind doing me a favor? Go to play store and install "Add away" then click "disable add blocking" inside the app and tell me if your wifi problems go away. I cant decide if add blocking is the problem or not. If it is, I may have to take out add blocking in my ROM.
bmcl1993 said:Sorry I want help, but I can't help because my tablet don't have play store, is for play store how I want install this rom
What is the problem with wi-fi???
dbeauch says that it is sometimes hard to connect to WiFi sometimes.
bmcl1993 said:But your tablet have any problem???
And dbeauch have other tablet is the Coby MID1125
bmcl1993 said:You can't make a video changing the ROM of tablet? Or put some photos/Screenshots of the process?
You mean of installing cwm or installing rom after cwm is installed?
bmcl1993 said:Everyting if you can... =S
Right now I'm installing Ubuntu 12.10 on Oracle VM VirtualBox...
Edit.: Can you tell me a Linux light??? (the Ubuntu 12.10 in Virtual Box is breaking :S )
You can try slitaz
bmcl1993 said:And this works to change the rom on tablet?
Its a linux os
bmcl1993 said:I have SliTaz installed now...
What I do now???
