I am using link2sd, and it works fine. I am still new to this, so I followed the instructions in one of the sticky posts.
The only thing I noticed is that some apps load to the sd, and some have to be moved with superuser.
I'm still trying to get rid of the bloatware, but the battle is progressing well!
Dave
I also have L2sd and work well for me. installed 2.2 then root, Just partition sd using easeus, mines 8g with 6g fat32 primary and 2g ext2 primary, rebooted and l2sd worked
I did all of that before but when I launch link2sd app I pick ext2 and it say cant find script????? I thought I didnt need it, or do I. I have the BB-104 S7
I downloaded the DLOAD folder and uploaded to my external sd card; however, when I boot up my tablet it just loads normally.
Has anyone had any luck using Link2sd or App2sd with 2.2.2? Ive been asking this question now for a week,lol. Ive been trying the link2sd with no luck.
Try removing the battery and reinserting it rather than just powering down and rebooting. On your external sd you should have just the dload folder with two files in it (make sure you don't put the rar file on the card, just the extracted folder) there is a .log file in the dload folder after you extract it, delete that before you put the folder on your sd card.
Ok I ran an md5check and it says that the codes do not match, but this is the code that was generated 74D031FD717D8BF68956EF3F044C8EEB. Sorry for being so ignorant, but this is a new process for me.Run md5check on the files
