[ROM] Indonesian Android 2.2.2 for Dual-Camera S7 S7v100R001C98B021
I have a Best Buy s7-104. I did this update within the last 20 mins. The instructions were on par. As far as I can tell everything works great including flash 10.2 from the market. Overall feels quicker and more responsive I rooted using SOC it acted goofy but I had to go back in to SOC once the s7 reset itself and do it again to get the programs (busy box superuser etc..) to install. Z4 didnt work at all. I also happy to find out that with set cpu you can go all the way to 998 MHZ now not the 768 or so before when I had 2.1. Widgets work with ADW launcher too now! I also noticed you can select the camera in the settings to default to either front or rear(hopefully skype and fring and all that will work correctly. Good work guys I dont know how to do alot but I will test and find out what I can. And to think I was gonna return this thing for a Nook Color today haha
S7-103 here, everything except my GPS is working. Tried GPS Test and it says GPS is there but nothing is working (no satellites showing or anything)?
This forum and its ppl rock. This update seems to work like a champ. Thanks to our friends in Indonesia. We have been hanging on your evey post thanks for comming through!
one question, i have my internal memory partitioned (for the app2sd) so i have 2 partition, how can i put it back to the original (since with this rom it is no needed anymore)
thnaks
Haha me too. I got mine from best buy, but couldn't get froyo on it. I was gonna take it back but I doubt that now. I'm loving it!
as i installed this froyo this is what i have now
can be used to update recovery right? it boots but fails to mount
$ cat /proc/mtd
dev: size erasesize name
mtd0: 00500000 00020000 "boot"
mtd1: 00500000 00020000 "recovery"
mtd2: 0fa00000 00020000 "system"
mtd3: 02100000 00020000 "cache"
mtd4: 0a000000 00020000 "userdata"
mtd5: 00200000 00020000 "logo"
mtd6: 000e0000 00020000 "splash"
mtd7: 00200000 00020000 "misc"
$ mount <-and whats mounted ...
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
/dev/block/mtdblock4 /tmpdata yaffs2 rw,nosuid,nodev,relatime 0 0
/dev/block/mtdblock2 /system yaffs2 ro,relatime 0 0
/dev/block/mtdblock4 /data yaffs2 rw,nosuid,nodev,relatime 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
/dev/block/mtdblock3 /cache yaffs2 rw,nosuid,nodev,relatime 0 0
Hmmn, is anyone experiencing sporadic freezing? Or am I just crazy?
Sent from my HTC Desire CDMA using Android Tablet Forum
All working fine here. I am on the Australian Telstra S7-104 version, with two cameras and no internal memory. Successfully rooted with SuperOneClick.
Anyone done ADW Launcher yet?
