... it should work as long as the target partition is of equal size or larger.
Hiya mate you can flash these tablets without having to pull the internal SDHC out put the apad in usb mode and copy them over to the main sd card easy as that![]()
How do i do a backup please ? In recovery there is no option...An app is usable..?You should have backed your firmware up. I did not build this firmware for your batch. You need to find someone who has a backup of your original firmware.
Is it redundant if i already renamed phone.pak with RootExplorer..?To reduce battery drain, download Airplane mode wifi tool from market
I'm using Scanpim-Address Book Sync, which is quite good..!To see Contacts, use AnyCut to create a shortcut to the Phone intent.
If i extract from the rom those 2 apk will i be able to use and sync Contacts without scanpim and the Calendar..?Google ContactsSyncProvider
Google CalendarSyncProvider
Same as before, could i extract the black status bar from the rom..?Found a black statusbar mod
