johnnyspork
- Oct 25, 2012
- 4
- 0
Looking for a WORKING usb driver for this device for Windows 7 64-bit...
When I try installing the driver provided with iuw 1.2, it tells me the folder with the .inf and .sys files contains no drivers for the device. Also, looking for ANY .ius file that works with this device.
When I tried http://222.73.93.45/sysup.php?data=12.7.0.12&vcode=0 I got the following:
"è¿æ¥æ°æ®åºå¤±è´¥ï¼Access denied for user 'checknew'@'localhost' (using password: YES)"
hardware ID is 12.7.0.12... (This is the model without HDMI and USB ports, but with the webcam)
I'm able to get windows to recognize the device by doing the three finger salute (Menu, Vol+, Back) when powering on the device while plugged into the usb port, but it cannot find nor install any drivers. This device was given to me by a friend requesting I fix it, as it only boots to the infoTMIC screen. When I do the 3 finger salute without an SD card inserted, no notifications ever come up about factory reset. If anyone knows ANY way to get this thing back up and running again, even with the original firmware, even if it still has the SD safe to remove issue, I just want to get it running SOMEthing.... Any ideas?
Thank you all in advance for your help!
