SYNET7LP DS Model??
my mid is "synet7lp-ds",haw could i restore my machines"/local/storage".because my mid can not receglaized sd card ,i have nothing to repair my machine ,who help me to do zhe task?QUOTE=jmbach;160268]I have tried SanDisk, PQI, and PNY without success. 1gb, 2gb, 4gb, 16gb cards. High capacity and non high capacity cards. No go on all. Called Digital Gadgets several times before talking to someone. Stated that only non high capacity sd cards will work in it. They suggested to return it or RMA it. Might try to reflash it since I cannot find a way to do a hard reset. Ask Digital Gadgets about a hard reset and they said it could not be done. Anybody able to do a hard reset on this model?[/QUOTE]
[/QUOTE]
my phone number in china is 18983520418 thanks
You can probably go to settings>privacy>and factory reset.Thats what ive done with my synet7lp-ds Android froyo tablet
I own a Sylvania Synet7lp DS and am in need of a photo of the circuit board. In particular I need a photo showing "C-50." It is the capacitor near the power/charger jack near the edge of the main board. Thanks in advance. Alan [email protected]
Has anyone been able to actually get into recovery mode for this? I've been going through every method I've found on the forums but have not been able to.
Also, has anyone been able to get the custom rom by techvendetta installed on this?
model: synet7lp-ds
android: dg2.20
hwid: 12.7.0.12
firmware: dg2.21-7c3.b5
I am having the same problem as jmbach. I have a sandisk 8 GB Micro SD it is Formatted to FAT32. Formatted to 7.39 GB. Ive tried Factory reset but it doesnt solve the problem
Providing as much detail about the device in question usually will generate more discussion and further insight. Specifically, it would have been beneficial to know the Hardware Id "hwver" for this tablet. It seems this information is clearly printed on the box.
H/W ID# 12.7.0.12
S/N# SYNET7LP-DS098-004298
Using this information along with previously posted information on how Digital Gadgets is now providing updates produces the following GET command -
Code:
http://dg-support2a.com/sysup.php?data=12.7.0.12&vcode=0
Note the new update server but the rest of the string remains the same only substituting the Hardware Id "hwver".
This results in the following text string which includes the current "vcode" (Version Code) followed by the pipe symbol "|" and then the InfoTM Update Wrap file url.
Code:
[URL="http:// http://dg-support2a.com/update/12.7.0.12/P7901UC_Android_458764.ius"]107|http://dg-support2a.com/update/12.7.0.12/P7901UC_Android_458764.ius[/URL]
The update wrap file contains the following images -
Code:
Company: InfoTM
Board: error
FileNum: 1.7.0.12.1.1
Size 59 MB
Image List:
U0 (259 K) U-Boot-nand.bin 2009.08 (11 e6 9c 88 01 2011 - 17:19:15)
RD (170 KB)
LK (2328.5 KB)
ADR_USER (8.5 KB)
ADR_AS (58158 KB)
Further investigation of the images will provide further detail and insight to this new version of tablet.
CAUTION: Using the incorrect update file, specifically burning the wrong U0 "u-boot-nand.bin" image, will cause irreparable damaged (brick) the tablet.
this is great info, but im having 2 probs- first is I can not seem to download the firmware link comes back like its not there- never had a prob with the other server for similar models- anyone have the updated url? or the firmware file
2nd I cant seem to get the three finger or any other method to work, is it possible that upon performing the factory reset it will look at the sd card on boot for an update?
thx all first off- im new here you guys rock- I have 2 of these that do the no sd card bs- id really like to try to reload the firmware before I end up trying to cannibalize them for parts.
I have the same model. I can get it to factory reset by pressing power, volume up and the back key. I have done it several times and it resolves nothing. I really hope someone can figure something out with this, it seems like a pretty decent tab if I could actually load some stuff on it. If there is a key combo to get it to look at the sd card that would really help.
H/W ID# 12.7.0.12
Code:
Code:
Code:
Company: InfoTM
Board: error
Size 59 MB
Image List:
RD (170 KB)
LK (2328.5 KB)
ADR_USER (8.5 KB)
ADR_AS (58158 KB)
Sorry Brother but the url u have given here for getting that update file is not working. I am in need of this update as i have bricked my tablet. I have searched in many forums but didnt find the update file. it will be a great help if u can provide the file to some file sharing site and paste the url here.
My tablet specification:
SYNET7LP-DS
H/W ID# 12.7.0.12
