I don't want an iPad without a SIM, I actually don't want an iPad at all. I was just saying that I tried one and the GPS didn't work, it was a WIFI version only so maybe that's why it didn't work.I really don't know the iPad2 GPS SW. Theoretically speaking, it should work without SIM (and the possibility to communicate with the cellular network). But we never know which limitations the producer put in the SW. Apple is known of its approach to SW openess... But I can say that Android devices have functional GPS even without 3G access.
Anyway, why do you want an iPad2 3G without SIM? The data used by aGPS is minimal, only for positioning lock - but don't be confused with MAPS download, for those navigation programs that don't have pre-loaded maps - these can be a heavy burden in your data plan.
Just for clarification - was this iPad2 a WiFi only version? Because iPad2 WiFi only doesn't have GPS at all! Only the 3G versions do.
There are tablets that do have GPS. The Huawei S7 works without having a SIM installed.
Sent from my Bottle of Smoke using Android Tablet Forum
so many people are replying, with no knowelage about GPS.
If it says it has GPS, then it has GPS. End of story.
Read the specs if it says "GPS", then it has GPS. aGPS is GPS, you can not have aGPS without GPS.
If it says aGPS, you have GPS on steroids. You won the Lottery!
Sent from my Transformer TF101 using Tapatalk
"Some aGPS devices do not have the option of falling back to standalone or autonomous GPS." from Wikipedia
The vage reference quoted above, means nothing to me.
If you can name just one android device that has aGPS but no GPS then I will be well informed. And very gratefull that you would take time to share that knowledge.
