Thank you for quick response. Earphone does not work. This is not an expensive tablet. I dont know how much repair cost, i also have to pay ship and handling. I may aswell buy a new one though im not a big fn to buy new device all the time
Update, following all the instructions as I mentioned, still not working. I reset to factory setting couple times, not working. About to give up, i was about to check the repair cost vs buying the new one. Then i suddenly heard the sound. Then i found out this tablet complained about low baterry. The important thing was it emits the sounds. I checked the voice work.
How i dont know. There is a bug on tablet. Download certain files trigger sounds file. Factorey reset will not do it. Does low battery trigger it to works. I dont know. It makes no sensr. Like many computer users say, there are ghosts inside computer. I always laugh on this concept. Should i believe now?
