Too much fast battery discharge
pedrojb
18
Hello everybody,
My S7 is discharging too much fast the batteries.
I charge them from AC original charger adapter and after about 15 minutes looses all capacity.
I use froyo 2.2.2 (indonesia version I think) and it´s rooted.
Do you have any ideas what can be happening, or any tips to try to find any "suspect" problems?
Thanks in advance and best regards
pedro
Did you leave it on charger most of the time? manufacturer don't tell you that you can kill your battery by never allowing it to fully discharge.
