yann2
- Jan 24, 2012
- 414
- 48
- Thread starter
- #16
I have some questions now. I can't install Google Currents. Also it seems that gmail isn't working. Keeps saying that it's waiting for sync
You would have to enable Apps Sync'ing by default - it's in the Settings. Also. make sure wifi is on and connected, I keep it off unless needed to save battery life.
I haven't used Google Currents, why can't you install it? Does it show in the Market at all for you? (sometimes Market thinks something is not compatible, etc, and won't show the app)
EllenLucas, thanks, glad to know the tutorial helped.
CM7 is so much nicer than the stock le pan firmware!
EDIT : Just went looking for Google Currents, and indeed the Market doesn't show it on my tablet - the page for it is HERE.
You might be able to tweak Build.prop and make it work with some different strings for brand, model, manufacturer. It only requires Android 2.2, so it should be listed.
** I just tried some Build.prop edits, and clearing market data/caches, no luck. It's possible it is only offered to USA users, like Google Music.
