What apps will bring up the menu? Just not sure what you mean by 3G toggle. Thanks!
Wait, scratch that. You mean like one of those widgets that allows you to turn radio and other services on/off with a press?
I'm going to try Widgetsoid2.x.
After installing, go to add a 1x1 "Switcher"
Widgetsoid2.x will open
Click Network from the bottom options
Check 2G/3G
Apply
Close Widgetsoid2.x
Go to the screen you put the widget on and press it. It will bring up the Mobile Network Settings
Uncheck Data enabled
Hope you find this helpfull
Built into the OEM. That's great (...sarcasm alert!)
I know nothing about Android since this is my first, but is there a way to get the original OS from google and install it on the device?
