Two days ago I used autonooter 3.0.0 to try to root my NC 1.1.0. It would not boot up or turn on at all. Yesterday when I got home from work, I plugged it into my PC and was told battery was too low to boot. I charged it to 100%, then it booted up. I checked, and to my surprise I was still on version 1.1.0. So, it was not bricked.
Last night I tried autonooter 3.0.0 again....same results. My NC won't turn on...and when I plug it into my PC. I get a "RNDIS\Ethernet Gadget" found message, then the "Found new Hardware Wizard" opens up.
Is my sd card flaky, is the card not properly seated in the NC, or is the NC card slot bad? I tried booting a CWR card to restore my NC, but get the same messages.
I will check the status of my Nook when I get home from work today and hope the battery drained, so that after a re-charge I will be back in 1.1.0. Then, I plan to take it back to B&N for an exchange........unless someone knows what my problem really is.
