- Jan 6, 2011
- 5,172
- 899
jostarr, when you put the card in does it "click" into place each time? Before giving yourself another headache with autonooter 3 you should go ahead and try rolling back to 1.0.1 and using autonooter 2.
I think that is going to be the quickest easiest way to find out where your issue lies. I know you have said you are not a fan of changing from 1.1 but you have tried that engough times to try something else at this point. there are no downsides to going with 1.0.1 and autonooter 2 and you will have the same great android experience to try out if it goes through.
From there on you can figure out if trying to get back to stock with 1.1 and autonooter 3 is worth it or if you just want to go with the 1.1 preroot.
