Severe Battery Drain
Off topic here (sorry), and I have to admit that I haven't been cruising the Nook forums as often as I used to, but is the CM7.2.0 RC3 worth the upgrade? I currently have V7.1.0 RC1 installed.
It is actually good to see you back around here :) Some will say yes, but I say no if you are happy with what you have. If you are comfortable with the whole flashing ROMs thing and have it down pretty well, then make a nandroid and go for it. If you don't like it flash right back to where you were. On the other hand to a casual user the changes probably aren't enough to be noticeable.
JP
Thanks JP. I'm in a happy place at the moment as far as the NC is concerned. It does everything I want/need it to so I think I'll stay where I am.
