Any one app you are having problems with finding the settings in, just ask. You can also just put the tablet into airplane mode which will still allow you to read anything on the tablet but will disable a lot of other "stuff".
Airplane mode does not disable use of the tablet but it does disable communications. It's not the same thing as blanking the screen, (sleep mode), or turning it off.
