Okay, I'm at the Stock recovery. That's a good place to start, now we'll try to unzip... the "fake".(smilz)
Darn!
Wiped data/factory reset, apply update from external storage...
--Install /sdcard ...
Finding update package...
Opening...
Verifying...
E:failed to verify whole-file signature
E:signature verification failed
Installation aborted.
(sighs) Well, now I feel like...(sighs) I know you been bustin' your hump on this one!(sighs)
One dumb Q:... do I need to rename the fake to " update.zip ", as per the usual?
it wont flash through stock recovery, that's why I had to modify your recovery. It will flash through the modified recovery.
Very promising. Just read it quickly, have to go out for a while. The advantage to CT's method produces a partition which can then be duplicated without manually loading. Again, promising. This Idea was in the air, seem lots have been thinking alike !
BTW, bludot just posted a 8065 boot.img. Looks good, went thru your extract script completely, thats progress. Its posted on my request thread.
http://www.androidtablets.net/forum/coby-generation-4/62743-8065-users-require-stock-boot-img-help-custom-firmware-development.html
