- Nov 8, 2011
- 3,836
- 1,394
- Thread starter
- #121
Flash_image will work on most tablets that use mtd partitions.
Sent from my SPH-D710 using Android Phone.
If you have enough memory on a system, you can boot ubuntu from cd, install the SDK tools only and run from cd. (vamp tip)
Don't give up on the 7033. A brick is exactly what we want to recover. I noticed the prices on all the broken Coby's. It's probably cause they heard of vampirefo's new recovery methods. ;-)
One thing you could do to avoid ADB on the 8065 for now. Root it using vamps 7065_root.zip from fake recovery. Then you could use adbWireless to make a system dump. No ADB required (just a short term solution).
Edit add:
ADB is still used to make and copy system backup files. Just no drivers are required with wireless adb-
The kernel source code I use to build modules for my 7065 are below, won't help you on 7033 but will work on 8065 provided we get a boot.img we can edit from 8065.
https://github.com/fards/ainol_elfii_common
@mcclain_ts
if your broken tablet wont boot from sdcard. you will need to look at Vortexflash.exe, I don't have a 7033 was told 7035 and 7033 can boot from sdcard, but if they don't then Vortexflash.exe is the only way, that tool from what I have been reading is only for windows. However it seems one can use the tool to recovery broken tablets, the first step would be to get it setup, then only flash a recovery.img or boot.img to make sure it flashed them, before moving on to system.img
ps FlashTool_EN.exe from my reading is just and english version of Vortexflash.exe
