- Nov 8, 2011
- 3,836
- 1,394
- Thread starter
- #166
its not there. i think the original rom had a separate zip file that was needed to be flashed to be able to hide it
It might have been, I don't remember, I use cm9 and cm10 on my tablets.
I might try to get aura ROM working for MID1042 because I am tired of these wifi issues
When I say stock I mean coby stock not aura stock, the WiFi in this Rom was copied from coby 7042 and 8042. However the WiFi for cm9 and cm10 work great for me.
Can someone please help me? I have the 8042 and I flashed this ROM and now my touchscreen will not work.
Restore your backup.
After I do that what do I need to do to get this ROM working?
Ok thanks.
I will try that first and see what happens
I got this to work
8042-no-touch-functionality
I think cm9 ROM offers more, I use cm9 myself. I am currently working on cm for 7042, but down fail to cm10 is weak WiFi.I am currently on your CM9 rom for the 7042. Would this Aurora ROM be better? Or should I just stick with the Cm9?
You mean you copied wpa_supplicant, dhcpcd and the other binaries or do you mean one of the frameworks (/system/framework)
Edit:I am excited to say that this rom without modification works with 1042. I didn't flash it anotomously as I did check update script to make sur it wouldn't screw anything...but that means that all 7042 and 8042 roms might work with 1042.I can't test if wifi is any better but once I get home I can.
