Stelv
- Jan 12, 2011
- 800
- 53
Thanks Srelv. If I understand you correctly you are telling me:
1. That booting Froyo (2.2) of a sd card is risky. What are the risks?
2. Autonooter is the best most stable way to root the NC at present time?
3. To root with Autonooter, I will have to roll back from 1.1.0 to 1.0.1 ?
Last question...everybody says to do a back up before rooting. How do you do that without installing CWR? I thought CWR could only be installed on a roooted nook???
1. Well certain versions of Froyo for the NC are experimental and may do some weird things to your nook, even if running off sdcard. But I am running a new Froyo rom that just came out yesterday at it seems stable now. First I had to autonooter and then install clockwork. I do not reccomend froyo if you are just starting out.
2. Yes autonooter is most stable tried and tested way to root. Most of us here have done it and can answer your questions on that. Please note though there is a bug with clockwork recovery and autonooter 3. Autonooter 3 would be to root a 1.1 nook. That is why I suggested rolling your device back to 1.0 and sideloading 1.0.1 and using autoner for 1.0.1.
3. You don't have to roll it back. Just make sure you are using the correct autonooter for your firmaware. If you want to roll it back it is somewhat of a process.
You cannot make a backup without root and a clockwork recovery at this time.
Here is what I did with my device:
-Bought it.
-Registered.
-Made sure my device was on 1.0.1 (optional just use correct autonooter for firmware. Cwr is buggy with autonooter 3)
-Rooted with autonooter (Nookdevs website)
-Installed replacement launcher from android market (zeam or adw)
-Tried out/used my rooted autonooter nook for a while
*from this point on it is harder to bring it back to unrooted stock, but can be done*
-Researched and installed clockwork recovery (Ricos guide)
-Made a backup with CWR
-Then since I am familiar with android and using custom roms I loaded the phiremod rom through cwr (hold off on this if a beginner)
