[CFW] GingerLF EVO - Custom GingerBread Android 2.3 for MID1024
If a game or program behaves like the tablet is always rotated tona side, the it thinks tablet has a giroscopy, which it doesn't so it will never work (one example is NFS Hot Pursuit). If it seems that x and y axis are exchanged, then go to Advanced Settings and change the Gravity sensor setting.
The hidden gift is the Microbes LWP. ;)
Changing the gravity sensor setting fixed everything! Thanks again, I'm really living this rom.
Sent from my GT-P1000 using Android Tablet Forum
Android Market is giving me a Force Close (com.android.vending) when I click on the app I want to install. However Apps Install fine using the Website and Pushing the app. Anyone have ideas?
This ROM is great. Thanks.
paco
MID1024 GingerLF Evo
HTC EVO 4G CM7.1
If don't have the latest version then install Hotfix as explained. You can check if you need hotfix or not by opening Terminal Emulator: if it force closes too then you need it. If you have the latest version then maybe going to Settings and clearing Market's data should fix it.
Hi IFOM
Do you think elaborate a honeycomb rom in the near future?like steev for coby7024
best regards
I'll work in the same project as steev, but only when I get home in about 12 days after my vacations. ;)
Hi Guys,
Noob here, how do I install this rom on MPMan MP1027?
Thanks.
Replied on the other thread. Pls don't post the same question on more than one topic.
LF, Looks good so far. I am going to make it a point to run on the HC theming for a while. in the past I was just too hesitant to use it and stuck with the GB theming. so far this one looks slick. I did a full wipe so I gotta get everything loaded back on thru TB then I can test it. I really like the way the brightness, wifi and sound are handled now. that is WONDERFUL!!!!
one question. I want to remove Aldiko and the Portuguese keyboard. TB wont let me as it says it is a system app.
For whatever reason, tb pro wouldn't let me remove system apps, either. I used rom toolbox instead. I'm not sure if the feature is in the free version as I have rom toolbox pro.
Sent from my HTC Vision using Android Tablet Forum
I've noticed when going back to launcher home screen the apps are shifted over and I have to move the home screen.
Sent from my rooted, baked, Gingerbread rocking Kyros MID1024
