[CFW] GingerLF EVO - Custom GingerBread Android 2.3 for MID1024
No need to remove those apps, they are in the Vendor file system, so they don't use internal space used by installed user apks.
How to disable B button shortcut (Quick Launch): use TB or Link2SD or any other utility to freeze Browser.apk.
Thank you lfom for this xmas gift. I have installed on a mpman 1027
this is the same pad delivered in France. Your rom is nice.
Merry xmas and Happy New year
+1
To access to the french apps in the market (like freebox mobile) I've install before all the apps "market enabeler" from here, and use the code 20814 (freemobile) and then, without close this apps, opened the market for the first time. Now without run this apps, I can use specific French apps from the market.
[translation in french : pour avoir accès aux applications androïd spécial marché français, il faut installer market enebeler et utiliser par exemple le code free mobile 20814 et garder cette application allumé pour le premier lancement du market, vous serrez alors enregistré non plus comme utilisateur T-mobile, mais free mobile]
Seem's like evrything have least bug with this mod that with the original OS (2.2 for me).
Great thanks for the job (and a special tank's for the brightness control).
I'm sorry, noob here. What do you mean by "It is recommended that you run fix_permissions using Terminal Emulator as root or adb at least once after installing the new version. "?How exactly do I do that?
Simply open Terminal Emulator (it's included) and run the command. It's optional tho.
glad its optional. ive never done it. LOL!
Hey LFOM, get this. I now have a Galaxy Tab 10.1 to use for a daily driver so I can really test on the Kyros!
Hi Lfom,
Problems with G5 games: paranormal agency,mahjong artifacts,spécial agency détail,crash for the 3 apps
Hi Lfom,
Which ROM are you using? You signature says it's another version, so I can't help...
For V1.5 EVO, my experience with Glu games is that some require a lot of free memory, so I simply run FMR before starting the game.
So the 1.5V is latest and greatest out there? I just downloaded it last night. It is very nice. How do you het the dancing Android on the load up screen?
Sent from my PC36100 using Android Tablet Forum
All the patches are added to the OP. So far, there isn't any. If you want to replace the included boot animation, simply replace the file bootanimation.zip in /system/media.
Before i use evo1,5 to wait your answer i have flashed with evo 3.1.1
