Haipad with Android 2.2 Hot!
2.2 HY works pretty good, no soft buttons, battery is always full and claims usb charging.
also, if you unplug the usb, the icons dont leave the notification bar, and the default language is chinese
I didn't flash mine since decompression says CRC is wrong.
Did yours say the same ?
What about market and flash?
Sent from my Android for Telechips TCC8900 Evaluation Board (US) using Tapatalk
o_O you are right!
sha1 is different so my upload is broken!
i will upload a version with corect CRC soon, sorry!!!!!
//removed old link.
//EDIT 2:
new upload:
http://www.multiupload.com/ZNSZ1HKW5I
Please check the SHA1 after download, it should be
SHA1:3964398626B88BEC731D2BB77A121C05799E0FAD
Also check the archive for CRC errors.
Thank you very much!
Tomorrow morning I'll get it
Stay tuned!
No.
The Herotab C8 / Dropad A8 has a Cortex A8 Samsung 1GHz processor.
This Pad has a Telechips ARM11 720 MHz processor.
Thanks for the upload it worked like a charm.
Seems fast and responsive, market works good.
Now I'testing
Sent from my M701/M701R using Tapatalk
Some apps don't show in the market like flash player and Firefox.
YouTube app works fine and avi files play too.
It still "thinks" to be a phone and shows icons in the bar and has no soft buttons as already said.
The tablet plays fast and till now I had no troubles with my home's Wi-Fi.
Sync of calendar works with my company's server too (egroupware) so I'm happy till now.
Now I'testing
Hi, Can you tell us from what link did you get the file with the correct CRC?
I have upgraded and noticed that the tablet gets very hot in the back and I haven't stereo sound. I'm considering to came back to the original. Has anyone the same problem?
It's reporting ARMv6-compatible processor rev6 660.0 MHz
What I did wrong?
Couple of problems to add to those already listed above for the 2.2 4GB HY by albertdsh:
  • HDMI Out works on TV, but sends my tablet screen crazy - wavy lines that are impossible to see what you are doing
  • Bluetooth doesn't work
  • Speech Recorder crashes (though Camera recording sound in video is fine)
Back to 2.1 for me... :(
ws
Also it always says it's charging and battery indicator shows always full charge even when unplugged .
I miss stereo sound too.
I tested the 2.2 firmware on mine (I think it is not a HY but it has 4GB) and i had the same problems:
Not stereo sound
Not sound for video player.
there is not YouTube app on the market
Wrong battery indicator
Not stereo sound
On my HY I found the YouTube app in the market and it runs OK with video and sound (not stereo of course )
I also noticed a very slow boot process, much slower than 2.1.
Every time it boots SD is scanned for new media.
