Stelv
- Jan 12, 2011
- 800
- 53
I made the following post in another thread. I would still stay away from froyo though and go with an autonooter method. You can load a froyo rom later once you get clockwork installed on your 2.1 autonootered device.
I am not sure if this helps, but if trying to root with a Mac you need this bit of info. This was provide to me by thel8elvis
Originally Posted by thel8elvis![]()
Put the downloaded .img on the desktop. Open terminal. type (no quotes) "cd Desktop"
Now when you type in the dd comand it should work. The problem was that the OS did not know where to 'find' the input file (your downloaded.img). Since it is on the desktop, and your terminal is now working from the desktop (cd Desktop) it should now work.
