HELP PLEASE!! NEED To Get CM10 On My NOOK HD+
slow_mo_panda
9
I am wondering if I have to buy the 32gb N2A card for $60, or can I buy the 8gb card cheaper and then transfer ALL files/content on the card (the CM10) to my own 32gb card? I also need to know if I can just root it myself to the CM10 version, because at this time I cannot shell out that much for the root program. Also, any help on where I can DL for FREE this CM10 software for my Nook HD+ would be awesome! I have not used my Nook at all as I can't stand the UI and the software. Thanks!
Devices - CyanogenMod
Go there and pick your device for the ROM you need, The Rom will already be rooted once you flash it. Keep in mind the only releases they have for your tablet are nightly which can or can not be good. I have actually had good luck.. Hope this helps.
