- Thread starter
- #31
Nice to see you have fun.
I'm going crazy with cm10.2
My kernel just bootloops the hole day.
Do you have the CM10.2 build already??
First i wanted to build a running kernel.
And here it is: a2109a-kernel5.zip - 4.62 MB
The kernel boots up on my installed cm10 from superhansi.
I don now if everything is ok with that kernel.
Antutu says 14450 points...
Right now i have started the brunch of cm10.2
I will tell you tomorrow if the build boots up.
That is just my first try.
Yes i will gonna build with a newer toolchain.
I tried linaro 4.7 but too much errors and i'm not a dev to fix all probs .
And i started a gitrepo so that everyone could See what i have done.
Go, go ,go, after you get a working cm10.2 rom , go and buy a Motorola moto x developer edition and start work on kitkat
Nice to see this tablet still has some life
Sent on my Moto X
I nearly fixed up all errors to use gcc 4.7 to compile the kernel.
The Kernel doesn't boot if i use any bmcdhd configs.
Without bmcdhd i get a booting kernel but no wifi.
So the work is still in progress..
nothing to show for now...
# CONFIG_BCM4329_RFKILL is not set
# CONFIG_BCMDHD_WEXT is not set
# CONFIG_BCMDHD_CFG80211 is not set
# CONFIG_BCMDHD_NOAPI is not set
# CONFIG_SD8797 is not set
# CONFIG_BCMDHD_FXN_125_120 is not set
# CONFIG_BCMDHD_FXN_195_89 is not set
CONFIG_BCM4329_RFKILL=y
CONFIG_BCMDHD_WIFI_CONTROL_FUNC=y
CONFIG_BCMDHD_HW_OOB=y
# CONFIG_BCMDHD_FXN_195_26 is not set
CONFIG_BCMDHD_FXN_FW_PATH="/system/vendor/firmware/bcm4330/fw_bcmdhd.bin"
CONFIG_BCMDHD_FXN_NVRAM_PATH="/system/etc/nvram_4330.txt"
CONFIG_BCMDHD_FXN_125_120=m
I have changed the bcmdhd settings but still no wifi...
But meanwhile i build a cm10.2 to see what happend.
and that's not much
Just blackscreen. ADB says something from egl errors, audio power errors and a lot more...
If someone wanna take a look on it : cm-10.2-20131109-UNOFFICIAL-kai.zip
For me it's too late today.
