- Jan 6, 2011
- 5,172
- 899
Now I'm home and trying to fix this. @J515OP, I have no idea where to "Keep it simple and find the CWR 3.0.1 zip file". I googled it, hoping for a link to a direct download- no luck. So now I thought I decided to use the second option I posted above, following @darmeen instructions. Well that post doesn't say 3.0.1, it's 3.0.0.5. So I guess I'll just use that one?
This has not been fun. All I did was follow the steps at the beginning of this thread. It's a shame that the key pieces of information that would have saved me this trouble are hidden somewhere within the 50 some pages that follow. (Key info being, DON'T do this if you have used auto nooter 3.0).
Anyone else awake this morning to offer me some help?
EDIT: Found this: http://www.androidtablets.net/forum...le-cwr-msd-v3-0-1-0-ext3-ext4-compatible.html
I have no idea what a .rar file is, but maybe that's what I need....
Ok Jonsey, here we go. The CWR 3.0.0.1 zip file is all over this forum (and use to be in the first post of this thread with the insturctions), I am sorry you weren't able to locate it. A rar file is just a zipped zip file. What you have to do is unpack the rar file leaving a regular zip file.
The thread you found will work and faceman even provided the rapidshare link directly so that you don't have to get just the 3.0.1 zip but the newest 3.0.2.8 is now there. Here is the official thread for CWR http://www.androidtablets.net/forum...422-recovery-official-cwm-3-0-2-8-update.html.
Here are the steps to fix your boot loop issue.
Make sure your nook is powered off and remove teh SD card.
Insert the card in to your PC or card reader.
Download this file cwmr_3.0.1.0.zip and place a copy of it on the root directory of your SD card (the main part of the SD card not in any folder).
Insert the SD card into your nook.
Hold the power and n buttons at the same time for 5-8 seconds. This should boot you into recovery.
Then when you boot into CWR do the following:
-install zip from sdcard
-choose zip from sdcard
select the CWR 3.0.1 zip file you saved to SD card and yes.
When done select reboot and you should boot into Nook as usual.
JP
