How can I use my front camera using fring vdo. Please
Sent from my S7 using Android Tablet Forum App
Greetings. Im a new user to the S7 and I purchased my device this week from Best Buy. Model number s7-104. My main issues is getting the data and voice to work. I use ATT for my cell phone provider. I rooted the device using z4root went through the steps to set it up but no luck. Can anyone provide any more tips or suggestions I could try to get it to work. Also when I entered the APN settings then press menu and select save it just goes back to the previous menu. Do the APN setting actually show up in the APN list after you enter them ? Any info is greatly appreciated.
There have been numerous discussions on this topic here on this forum. Here is a link to one of them http://www.androidtablets.net/forum/huawei-tablets/2948-t-3g.html#post17053 Welcome to the S7, hope you enjoy it.
thank you for the quick reply. I went through the post and tried the steps he listed but it still doesnt work. The S7 sees my sim card because the ATT pops up after the reboot after inserting the card but no luck with connect to the data or voice plan. Any other ideas ?
thanks for the help. i correct the problem and now my S7 connect via my sim card
sorry, i posted this on another thread, but replies seem slow, so perhaps here I might get a reply... Do I need to root my S7 first before I can make my ATT voice and data plan (contract) working? Currently, it detects the card when inserted (no bars) and I have tried to set the gsm/wdsma (?) and APN settings on it, but so far nothing happened..
Thanks for the reply. If I can't make this work, I'll have to return it to BB and get a refund I guess, since this is the 3rd replacement now.![]()
