ok my first post, ive been trolling hoping for a newer android os on S7 and what nots. and till my s7 2g internet stoped working....
IDK if this has been posted but i found a fix for mt T-Mobile Data plan.
For some odd reason my internet on T-mobile stoped working, and would only go to my.t-mobile.com with any web addy entered. after talking with a teki and wanted me to pay 14-50 bucks extra on my data/voice plan...and no garentee it would work.i did some reasurch and testing.
i found my MCC and MNC to be in error. I used the settings from androidcommunity.
APN: epc.tmobile.com
Proxy: <not set>
Port: <not set>
Username: none
Password: none
Server: *
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy: <not set>
MMS port: <not set>
MCC: 234
MNC: 30
APN type: <not set>
again some how either after reset my settings got funky or what..cause i thaught it would work right out of the box with T-Mobile.
also a side note befor i changed mt apn settings Facebook would reconise devive as a motorola pebble or blur or something LOL. when i was on wifi that is.
Hi Viago,
I attempted my regular tmobile sim card with the settings you provided but got nothing. I just wondered if you intended to put bng in the middle of the MMSC setting rather than eng. I use that MMSC setting with my prepaid data sim and it works fine.
Thanks.
Sheila
