Jellybean R3 For 1024n by :NAMKO
Kairnage said:
I got it installed but it definitely has a few more issues. What I have found so far -
No WiFi - scans forever then shuts down
Capacitive buttons very slow and unresponsive
System shut down randomly
default prop is set to ro.secure=1
ro.allow.mock.location=0
ro.debuggable=0
persist.sys.usb.config=mass_storage
should be
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
Video snow comes back every other time it comes out of sleep or reboots.
Still an awesome effort. Hopefully some more people will get involved.
We need to edit the default.prop right.
Edit: I Made a thread on how to edit default.prop
If someone has the brains,
Pls help .
Ok I Kinda Go To The CM9 Right Now ....
But Ill be Right Back Bros
PLs Dont Close This Thread!!!!!
:cool:
If you install google search microphone works.
The allow mock locations and usb debugging you can set in developer options (after switching on with switch in top right corner)
Thnx for the tip bro!
This Rom is awesome!!! It works realy nice.
But there are some bugs I found:
1. Snowy display return after reboot
2. After battery dead I could not pass throgh penguin screen. I had to flash again
3. Volume buttons dont work
4. Volume popup appear randomly after harware back button press
5. HDMI does not work
6. I did not findout how to connect any usb device
7. Screen orientation is slow
8. Launcher brackes randomly
9. Search application breaks randomly
You guys did nice job. I hope you will continue working on this rom because it realy aswesome. Thank you!!!
Ok Bro i Will find Fixes For The Rom
Umm Pls Look At First many Fixs Are there ^_^
There are another several bugs I found:
1. Green line on the screen when I watch movies on youtube and some other players.
2. Youtube video is lagging randomly.
I found some issue with touch screen when play games. For instance angry birds space stops recognisong single press. to push the bird i have to keep one more finger on the screen. Also my kyros cannot boot after i chage dpi to 160 or 150.
device shutdowns when i switch wifi off. wifi sleep mode does not work too. this one is critical for me. wifi kills my battery when my coby sleeps.
Just You wait Guys Pls Wait Im Having Troubles With The Rom
@galulex Pls Dont Spam And Pls Dont Change Your Dpi At 150 Always 160
@luwe Just Wait ^_^
