johnny_luck
- Nov 1, 2012
- 25
- 0
- Thread starter
- #16
im done rebooting it sir.. still stucked on coby logo.. should i boot again to recovery?
johnny_luck said:sir, i have a question... y is it there is only 1 internal memory left in my storage? i think there is two internal memory other than the external sd.. thanks sir...
johnny_luck said:is there a way to fix this sir? thank you very much for your help sir.. i can't really imagine that someone will help me and give me spare time for this..
Couldn't he pull a copy from one of the 9042 system dumps and use that?You would need to get someone who had the same system as you had to give to you. Its not need at all, but you can ask around til you find it if you want.
