johnny_luck said:you now what what i most appreciated in this furom is that we are helping each other... and the best part you can be helped out rit awzy.. ive learned allot of things here.. sir vampire i think that the 7042 have also the 2nd intrnal memory.. can u check it sir if the vold.fstab have something to help... sir vampire thatit is in the vold.fstab lies the solution of my p/roblem? thank you very much...
I have made another 9042 installable rom based off of joenarsu12 dump.
9042_joenarsu12.zip
http://www.androidtablets.net/forum...neration-3-devices-post249753.html#post249753
I don't know if it will help you or not.
