- Thread starter
- #91
I've just been using the Battery option under setting. It says 62% of my usage is screen. It also says that Maps has been using 16%. Why Maps is running, I don't know. It rarely leaves the house.
What I do find interesting is that instead of the constant orange when charging, it's pulsating an orangy-white. I've never noticed it before.
I wonder if it's related.
62% screen is normal.
16% Maps is high.
These numbers are highly dependent on when you check them. Check them right after coming off the charger and they are meaningless. After a few hours they give a good idea of how much battery is being used by each app.
Some websites that know your location (Google news for instance) use components of maps to determine location in ICS, so this may be misleading. Go into running apps in the settings and kill maps, or anything else that may want to know where you are, like checkin services etc.
Orange = charging
White = accessing the web, checking mail, checking for updates, facebook etc. Find those apps that you do not need to be constantly checking and uncheck them under accounts an sync. Tap your gmail account in accounts and sync and turn off any components you don't need synced. (Really, I just don't worry about this that much, since its only wifi traffic).
