driftinganomaly
- Aug 8, 2012
- 43
- 11
It may be easier to just use adb and reverse the changes that you made to the build.prop . I don't know a lot, but that seems like the logical place to start.
Folken:
After I got my 7035-4 rooted I wanted to change the LCD-density from 120 to 140. I modified the build.prop file and and rebooted. The tablet does not unlock anymore and show SYSTEM UI HAS STOPPED message.
I could not find a forum from where I could download the factory ROM.
Reading the previous page I found Vampirefo comments that one could restore using the Dump files so I used your Damp files for this tablet and tried to restore. I get a message that it can´t verify the files.
I will appreciate your help
I created an restore .zip files with the dump files
Folken:
Lanning,
Thanks for you comments. The Kyros 7035 reverts the Developers option DEBUG on to off after every reboot so I have no access to the device or ADB
Here is a link to the dump of a MID7035-4 rooted and gapps installed. If someone wants to clean it up and make it pretty for livesuite or create a custom rom go for it. Hopefully it can serve some help for anyone who might have bricked their tab.
MID7035-4-dump.zip
Hi Folken, can you or anyone here please tell me the procedure (step-by-step if possible) on how to get this reinstalled on a bricked MID7035. I have my device stuck at the ANDROID logo and it never moves, I'm able to get to recovery and do the WIPE but it does not do a factory reset so it keeps coming back to the ANDROID logo screen. I have tried copying the files in the zip dumb onto a sdcard but when I do the recovery from external and then select the MID7035-4-boot-bl-rec.zip, it bombs out with the error "E:signature verification failed installation aborted". I would really like to get this device back up. Thanks for the assist.
